LabWindows/CVI
extended ASCII Characters
I receive a message via the serial port containing Characters from the Extended ASCII Character set. I am wondering how I can convert them to a hex value. When I double click the variable in the variable viewer I can change the format to hex and it is exactly what I am looking for. But I cannot figure out how to modify the value. Note: I am not trying to display it just use it's hex value.
Thanks for the help,
Wade
(4,202 Views)
I think you can do this.
char buffer[256] = {0};
sprintf(buffer, "%x", hex_value_from_port);
buffer should display value in hex now.
Sheetal
Thanks.
CVI 2010
LabVIEW 2011 SP1
Vision Builder AI 2011 SP1
(4,194 Views)
That method works perfect for the normal ASCII Character Set (under decimal 127), but when I have a character in the extended character set it gives funny results.
Example:
Hex: 0xF1
Decimal: 241
Result of Output: 12fde8
Thanks for the help
(4,187 Views)
Try receiving the messages in a buffer of type unsigned char[]: a char ranges from -127 to 128 while an unsigned char is 0 to 255. The same bit patter in the two cases represents different numeric values.
Try executing these lines in the interactive window:
unsigned char b[10];
char a[10];
strcpy (a, "Hello!"); a[3] = 241;
strcpy (b, a);
DebugPrintf ("String A: %s - a[3] = %x (%d)\n", a, a[3], a[3]);
DebugPrintf ("String B: %s - b[3] = %x (%d)\n", b, b[3], b[3]);
Output will be:
String A: Helño! - a[3] = fffffff1 (-15)
String B: Helño! - b[3] = f1 (241)
Hope this helps
Roberto
Message Edited by Roberto Bozzolo on 05-20-2005 06:53 PM
(4,180 Views)
Thank you very much, that is what my problem was. I figured I had to be doing something dumb.
(4,175 Views)
