LabWindows/CVI
export from graph
Hello Group,
i need to export a plotted graph from a running cvi programm.
Which possibilities have i? Is it possible to export it as bitmap or
similar?
At the end i need to generate a PDF file with some basic claims datas and
the graph.
With best regards
Gregoire
(3,424 Views)
Look at the sample project clipbord.prj that ships with CVI. It uses the function GetCtrlDisplayBitmap() to get the image of a graph and put it on the clipboard so it can be pasted into any Windows application. You can also look at the function SaveBitmapToFile() to save a bitmap to a file programmatically without using the clipboard.
(3,424 Views)
thanks, that was exactely what i´m looking for.
Gregoire
"Al S" schrieb im Newsbeitrag
news:50650000000500000099CB0100-1079395200000@exchange.ni.com...
(3,424 Views)
