LabWindows/CVI
example C code for USB6008
Hello
Prior to buying the USB 6008 DAQ board, I would like to see some sample codes to program it in ANSI-C in Linux environment.
I can't find it on the NI website.
1- Can anyone suply me some sample code?
2 - How easy is it to program it? Any comments from users who did it are appreciated
3 - How do you access the NI libraries? Does one only need to make an #include on the begining of the code?
Thanx, regards
(3,527 Views)
As you are using Linux, only NI-DAQmx 8.0 and NI-DAQmx Base are officially supported. Once you have installed these libraries, you will get C examples with it (in C:\Program Files\National Instruments\NI-DAQmx Base\Examples). I have attached one of the examples given with NI-DAQmx Base.
I would say it is not hard to program it but have a look by yourself.
(3,486 Views)
