LabWindows/CVI
event = 6000 ?
I've set up a GUI using EasyTab. It works fine -- tabs at bottom, multiple pages, etc. When I RIGHT click on a tab, it generates an event = 5. But when I LEFT click on a tab, it generates an event = 6000. Any idea what is going on and how to fix it? It seems that a LEFT click should generate an event = LEFT_CLICK.
(3,012 Views)
event=6000 is a EVENT_TAB_CHANGED as defined in easytab.h, you should
receive it, every time you switch the tabs.
hendra@ssl schrieb in im Newsbeitrag:
5065000000080000005E3A0000-1011517314000@exchange.ni.com...
(3,012 Views)
