LabWindows/CVI
error: conflicting types for 'myFunctionOne'
The LabWindows/CVI 2013 help page for C Language Extensions appears to show function overloading being supported in the C99 extensions:
 "Function Overloading in C | Yes"
The table in the following link shows the same thing:
http://digital.ni.com/public.nsf/allkb/73AEAD30C8AF681A86257BBB0054A26B
I tried compiling a source file with the following overloaded function definitions with C99 extensions enabled in the Build Options:
 void myFunctionOne(double d) {
  printf ("Value = %f\n", d);
 void myFunctionOne(int d) {
  printf ("Value = %d\n", d);
and I get the error:
 "conflicting types for 'myFunctionOne'
Is function overloading truly supported, and if so, how does one enable it?
Mark B.
(9,090 Views)
Oh, I was a bit too quick, Constantin has the better answer Smiley Happy
(9,074 Views)
Accepted by topic author MarkB_CTC
Hello Mark,
You have to add __attribute__((overloadable)) at the definitions of the functions you want to overload.
void __attribute__((overloadable)) myFunctionOne(double d) {
void __attribute__((overloadable)) myFunctionOne(int d) {
You can see an examples of clang extensions here.
Constantin
(9,072 Views)
Thanks, Constantin.  Works perfectly.  Looks like there's a whole world of attributes out there - I see a research project in my future.
Wolfgang, thanks for taking the time to reply, also.
Mark B.
(9,041 Views)
I think you can also use the 'weak' attribute and/or pragma, although I haven't tried.
(9,002 Views)
Thanks, I'll look into it.
Mark
(8,998 Views)
