LabWindows/CVI
error code -33
I'm trying to build a project.  The first time it asks if i have the distributions it lists a project i had previously had worked on but have since deleted and dont have access to so i answer no to if i have the listed distributions.  After that it lets me tell it what distributions i do have and i check all that i do and go forward.  i then get the following message without any prompts to help the builder find the distributions and it errors out.
CDK_Build_Invoke.vi.ProxyCaller >> CDK_Build_Invoke.vi >> CDK_Engine_Main.vi >> CDK_Engine_Build.vi >> NI_MDF.lvlib:MDFDistCopyList_VerifyItemPresent.vi
Loading product deployment information
Adding files to installer
Done adding files
Preparing to build deployment
Copying products from distributions
*** Error: Input data from a source data file has errors. (Error code -33)
Error in ini file: D:\Distributions\MeasurementStudio 8.6\nidist.id
*** End Error Report
Error verifying distribution present: National Instruments Device Drivers - February 2009, Disk 1
Done building deployment
any help on this would be great as it is holding me up
(3,780 Views)
i found another post explaing to goto the registry and change the path of distributions with bad paths to the CD-ROM root directory so that it would prompt if it wasnt found, well i found a bunch of distributions in the registry named after my previous project.  is it okay to just delete these from the registry entirely?
(3,779 Views)
i dont know why i posted in CVI, i reposted here
http://forums.ni.com/ni/board/message?board.id=170&thread.id=401943
(3,776 Views)
