LabWindows/CVI
error: Undefined symbol at Vision Example
I have an issue to run Vision example code Load and Display.prj.
All .lib .h ..etc are included into the project (details in the attached picture) but something is still wrong.
What else is missing?
Thx!
(2,574 Views)
Did you try to remove nivision.lfp and nivision.lib from your project? Normally these shouldn't be included in the project. NI Vision library should be available under "Libraries" in Library tree.
After you remove the *.lfp and *.lib you might need to reopen CVI.
Constantin
(2,552 Views)
