LabWindows/CVI
empty folders
This occurs with several CVI versions (my latest is 2012). When using the function DirSelectPopup or FileSelectPopup and steering over to a folder that has numerous sub-folders or files, I often (not always) get an empty folder displayed. The only way to see the sub-folders or files is to back out one level and select that same folder again.It may take 2 or 3 tries before it works. It appears to timeout if there is too many sub-folders. Is there a solution to this annoying problem? I see it on Windows XP and 7.
Thanks, Mike
(5,508 Views)
Does pressing [F5] to refresh the view help ?
(5,488 Views)
Pressing [F5] has no effect.
(5,482 Views)
Can you try using FileSelectPopupEx instead? It runs on Win7 and uses a different set of APIs (on WinXP it results in a call to standard FileSelectPopup function, though).
With how many subfolders does the function time out?
(5,468 Views)
It appears to work with the Win 7 machine although the problem is intermittent. There are days when I see it all the time and others when I can't get it to happen. So far, no problems on the win 7 but still issues with the XP.
Thanks, Mike
(5,462 Views)
I forgot to mention that I do not know the exact number of folders that cause the problem. I believe when there are over 50, I see it more often.
-Mike
(5,461 Views)
