LabWindows/CVI
drag and drop a text
Bonjour,
Est il possible de faire drag and drop d'une zone text sous CVI?
Cordialement.
(3,006 Views)
Bonjour,
I don't think so. What does work is cut and paste...
(3,003 Views)
Thank you for your fast responseSmiley Happy, But, i saw that it's possible to drag and drop a file tree. Isn't the same thing?
Best regards.
(2,999 Views)
I guess I have to correct myself - the initial answer was the result of a quick experiment using one of my programs. So by default drag and drop is not enabled for strings. However, there is a function in the toolbox library that promises to enable Windows drag and drop, EnableDragAndDrop (int panelHandle).
Wolfgang
PS: The attribute ATTR_ENABLE_DRAG_DROP is avalable only for tree items and tab pages.
(2,991 Views)
Thank you a lot for clarifying the idea.
Best regards
(2,985 Views)
