LabWindows/CVI
dll prototype with no implementation
I'm wondering how it is I can have an exported function protype declared within a dll  and no implementation for it and it still builds without error?
Doen't an .exe build break when this happens?
Menchar
(3,907 Views)
Maybe the linker allows this because for all it "knows", the dll will load another dll with the implementation?
(3,888 Views)
for what i have tested, the compiler ignores the incomplete exported function: the function is not listed in the exported symbols of the resulting binary.
it is the same for an executable: if you declare a function but do not define it, the function is ignored. a link error is triggered only if you call the function from inside your code.
(3,864 Views)
Well, if it isn't really exported then at least it won't allow a client to try and invoke a non-existent function, which is what I thought might be happening.
I wonder what the thinking was in C on this issue - maybe it's a compatability thing since C doesn't require prototypes.
Thanks.
(3,848 Views)
