LabWindows/CVI
distribution kit problem
I'm using labwindows CVI 6.0 FULL and win2K.
My application is ready, I'm creating a distribution kit, I'm testing the installation kit from my hard drive and everything work fine. BUT....the problem IS: If I copy all the files to a CD and then trying to install it from the CD. I doesn't work, it says verify that its a valid installation bla bla...here is a snap shot of the popup error message.
We have verify several times that all files are identical to those on the hard drive, we have a 100% match. All bytes are there.
Please if someone can help.
thank you,
(3,406 Views)
I'm not sure what could be causing this. I've done this several times with no problems. There must be something with your project setup that is causing this. Try just opening an example program and building a dist kit, then installing that kit from the CD. That should work fine. If it does, we need to evaluate what you are doing in your project that is different that could be causing the problem.
Best Regards,
Chris Matthews
(3,406 Views)
Thanks, we found the problem, we tried another CD burner and it worked fine. It seems that even if we've checked all files, the Toshiba burner doesn't burn like the others.
(3,406 Views)
Good to hear. Thanks for following up.
Chris
(3,406 Views)
