LabWindows/CVI
distribution kit error
as explained here I was able to build a distribution kit. I installed it successfully on PC 1, ran the program, fine. Today I decided to distribute it to a different computer, PC 2 (actually the same configuration, XP SP3), created a new distribution, but now the installation fails with the following error:
I am attaching the ini file and hope that somebody can assist me...
Thanks!
(3,383 Views)
Did you copy the whole distribution before running the installer? The error indicates that the WindowsInstaller-KB893803-v2-x86.exe file in the supportfiles folder was not found. Can you confirm that it is there?
Mert A.
(3,358 Views)
Dear Mert,
I am pretty sure that I did so but because some later distribution worked fine, I can not confirm it at present...  If I'll run into it again, I'll check the support folder and update this thread...
Thanks!
(3,339 Views)
