LabWindows/CVI
display project version
I have looked and can't find anything on how I can display the project version on the front panel. (Project version I mean the same version that the Installer version uses). I have the Installer version checked to auto increment after each final build and I would like to know if there is a way I can display that same version on the front panel of the program for a quick easy of seeing what version is installed all the time.
(3,375 Views)
There is no easy way to do this using any of the CVI built in libraries, as far as I am aware.  I use the GetFileVersionInfoSize() and the GetFileVersionInfo() functions in through the Windows SDK, which should do what you want.  There is an example of how to do this in:
C:\Program Files\National Instruments\CVI71\samples\sdk\verinfo\
If you are using CVI 7.1 - I assume that other versions probably have it stashed somewhere similar.
(3,368 Views)
