LabWindows/CVI
define hotkey in CVI 8.5
I have to define a hotkey in LabWindows CVI 8.5.
The problem is that the hotkey for the action I set have to work also, if the program isnt the active panel.
This mean, I use the udts380 to read the measurements from an instrument. I defined the "Write Data" button with "ctrl + w". Now im working in Excel and I  want to press "ctrl + w" while excel is the active window.
I hope someboy can help me.
greetings
(3,523 Views)
I think it's possible, but you'll have to use the Windows SDK to do this. I think the RegisterHotKey function might be able to help you.
You'll probably also need to use the RegisterWinMsgCallback CVI function, in order to receive the corresponding Windows message.
Luis
(3,498 Views)
Maybe you can gibe me a code example for  RegisterWinMsgCallback CVI function ?
I'm a beginner in C, sorry.
thanks
(3,481 Views)
Although I don't have a sample handy for RegisterWinMsgCallback, you can look at samples\toolbox\msgdemo.prj. It uses InstallWinMsgCallback instead of RegisterWinMsgCallback, but the idea is the same, so you should also be able to use InstallWinMsgCallback as well. And there's also some sample code in the InstallWinMsgCallback function panel help.
Luis
(3,470 Views)
