LabWindows/CVI
database+deployment
Dear Sir I have developed an application in LabWindows, which connects to microsoft access database using the command DBConnect("DNS =Example") . I have used 'System DNS' for connectivity. I want to build its deployment version and require that when installer is run an computer, system DNS is created by itself.But I donot know how to incorporate this? I do not understand how to incorporate database and its connectivety in Installer. thanks
(3,141 Views)
Rahil,
This KnowledgeBase article explains how to build CVI applications that use the SQL Toolkit. As far as creating a database source name (DSN) programmatically,see this article: KnowledgeBase 2ST89LJY: Programmatically Creating and Registering a DSN in C++
Additionally, you may find these two links useful:
http://digital.ni.com/public.nsf/allkb/8D4A69C84D352BF58625706C005B48D2?OpenDocument
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019NiwSAE&l=en-US
I hope this helps!
Warm regards,
pBerg
(3,107 Views)
