LabWindows/CVI
data tool tips not showing all values
I just discovered that data tool tips do not show all variable values.
Given the following (meaningless) example, the data tool tip does not show anything if hovered over test_2.
(the break-point is after the last line shown)
Because it is generally recommend to reduce the scope of variables I suggest that this behavior (CVI2020f1)  should be improved.
(1,457 Views)
Accepted by topic author Wolfgang
Hi
The variable test_2 does not exist anymore when the program hits the break point.
Jan
(1,431 Views)
you are right... 😯 thanks!!
(1,427 Views)
