LabWindows/CVI
d
is there a error check or return value for     Ini_New( 0 );
or Ini_ReadfromFIle,  I want to do a check to see if the file is curently in directory, is possible using
 ini style from cvi., anythere any other error handling I can possibly do and why in this situation.
the send servo command function moves the arm on a robot etc....... in the x and y position blah blah
im just looking for any exception handling in this situation
 int Boresight_Command(double  *dAZposX,double *dELposY)
    char sAZposX[100]={0};
    char sELposY[100]={0};
    char sCrtCommand[256]={0};
    char sDirPath[BUF_LEN_FOR_DIRECTORY];
    IniText iIniTextHandle=0; // Handle for the text file.
    char sPathName[BUF_LEN_FOR_DIRECTORY];
    GetProjectDir(sDirPath);
    MakePathname(sDirPath,KEY_TEXT_FILE,sPathName);
    iIniTextHandle=Ini_New (0);
    Ini_ReadFromFile (iIniTextHandle,sPathName);
    Ini_GetDouble(iIniTextHandle,"RECOVER", INI_TAG_X_OFFSET_POS, dAZposX);
    Ini_GetDouble(iIniTextHandle,"RECOVER", INI_TAG_X_OFFSET_POS, dELposY);
    Fmt(sAZposX,"%f",*dAZposX);
    sprintf(sCrtCommand,"SERVO, WRITE, 095000000, %s",sAZposX);
    Send_SERVO_Command(sCrtCommand);
    Fmt(sELposY,"%f",*dELposY);
    sprintf(sCrtCommand,"SERVO, WRITE, 090000000, %s",sELposY);
    if(iIniTextHandle != VI_SUCCESS)
       //Cleaning memory
       Ini_Dispose(iIniTextHandle);
       return FAILURE;
    return VI_SUCCESS;
Message 1 of 63
(5,928 Views)
darnell,
Of course, there are error check values for both functions.
You can kindly see the help from the function panel:
Ini_New: "... 0 is returned if there is not enough memory ..."
Ini_ReadFromFile: "... A zero indicates success ..."
You can also use FileExists function to see if a file is available on disk.
Last, but not least, you violated another forum law by entering a meaningless subject for your post.
But you are always too ignoring to pay attention to such niceness, aren't you?
Message Edited by ebalci on 11-20-2009 09:17 AM
S. Eren BALCI
IMESTEK
Message 2 of 63
(5,921 Views)
In addition to the good suggestions from ebalci, you can use nullChk and errChk macros from the Programmer's Toolbox: they are well documented in toolbox.h.
int SomeFunction (void)
    int        error = 0;
    IniText    T = 0;
    nullChk (T = Ini_New (0));
    errChk (Ini_ReadFromFile (T, "myIniFile.ini"));
    // Sample reading function
    errChk (Ini_GetInt (T, "Section", "Item", &value));
Error:
    if (T) Ini_Dispose (T);
    // You may add some message here for the user if (error < 0)
   return error;
Message 3 of 63
(5,915 Views)
Sorry about that, I wasnt paying attn,I didnt try to do it on purpose.
int SomeFunction (void)///// are you sayinguse this logic in the function I already created, or create a function call and just call it
    int        error = 0;
    IniText    T = 0;
    nullChk (T = Ini_New (0)); ///////////can you explain?
    errChk (Ini_ReadFromFile (T, "myIniFile.ini"));/////is the line checking to see if file available
    errChk (Ini_GetInt (T, "Section", "Item", &value));////is this check to see if i got the value to the variable
Error:
    if (T) Ini_Dispose (T); ////and im assuming if anything fail above ,it jumps down to this point, and return error
   return error;
also im trying to search for a good book on error handling ,do you know of any?I want to take my error handling to the next level.
Message 4 of 63
(5,889 Views)
Here some comment and aswer to your questions.
int SomeFunction (void)///// are you saying use this logic in the function I already created, or create a function call and just call it
I was suggesting you a framework for adding error checking to your function. With the ability to return the error found (if any) to the caller in case you want to propagate it and trim the behaviour of your program in this case
    int        error = 0;
    IniText    T = 0;
Please review this thread about it and look at the documentation on Ini_New function
As you may notice studying the documentation, Ini_ReadFromFile can return several errors. In case the file does not exist you are likely to receive error -94. Use GetGeneralErrorString () function to obtain a description of errors returned by IniFile functions. And please open the function panel for Ini_ReadFromFile and right-click on 'status' field: you will see which errors this function returns (this is valid for every fp)
This check is in case you get some error while accessing the IniFile object. In case of non existing section/item you will receive error = 0.
Error:
Right: have you looked at the documentation for errChk and nullChk I pointed you to earlier?
   return error;
Message 5 of 63
(5,886 Views)
im getting ready to check with in a hour
Message 6 of 63
(5,879 Views)
do it like this
int Conversion_Number(int *Multiplier)//Functionality: retrieving actual
                                      //multiplier which currently is not
                                      //available
    int error=0;
    char dir1Name[BUF_LEN_FOR_DIRECTORY];
    IniText initextHandle1=0; // Handle for the text file.
    char pathName1[BUF_LEN_FOR_DIRECTORY];
    GetProjectDir(dir1Name);
    MakePathname(dir1Name,CONFIG_FILE6,pathName1);
    initextHandle1=Ini_New (0);
    Ini_ReadFromFile (initextHandle1,pathName1);
    nullChk(Ini_GetInt(initextHandle1,MULTIPLIER,INI_TAG_PIXEL_TO_DEGREES,
                       Multiplier));
    Error:
    if(initextHandle1)
       //Cleaning memory
       Ini_Dispose(initextHandle1);
       MessagePopup("ERROR","ERROR RECIEVED");
       return FAILURE;
    return VI_SUCCESS;
Message 7 of 63
(5,859 Views)
Where is all the error checking you asked about for Ini_New and Ini_ReadFromFile !?
Where is the code to check if the INI file exist or not !?
Are you still posting temporary code?
You can use the MAX_PATHNAME_LEN constant instead of BUF_LEN_FOR_DIRECTORY.
It makes your code more portable.
S. Eren BALCI
IMESTEK
Message 8 of 63
(5,854 Views)
Im confuse I thought you saud the nullChk was the check to see if the file is there, let me re read again
Message 9 of 63
(5,851 Views)
nullChk, as the name implies, checks if the return value of a function is NULL.
For some functions like Ini_New, NULL (as a return value) means the function was not successful.
Instead of assigning variables for return values and using IF statements to check if the return value was NULL or not, it is possible to use the nullChk macro.
It automatically reads and compares the value you provide (in this case the return of Ini_New) and if the function's return is NULL, it sends the execution to the Error label where you can handle the error condition properly.
Didn't you read Roberto's post? There is a whole function with error handling there!
Copy and paste it to your file and step through the code in debug mode.
Try the error conditions by yourself and see what happens.
This is maybe the 10th thread about your error handling issues. It seems we are not making any progress.
Message Edited by ebalci on 11-21-2009 10:18 AM
S. Eren BALCI
IMESTEK
Message 10 of 63
(5,847 Views)
