LabWindows/CVI
cwgraph
how can I draw 2 plots in real time with a time axis ( hh:mm:ss)?. Can you give me a sample of the good function to handle the time axis ?.
Thank you for any pointer.
(3,079 Views)
You can right-click on the graph and open the property page. Then you can go to the Format tab and change the x-axis format to Time. Then, you can call ChartY method to chart one or more plots, most probably in a timer callback function.
Mika Fukuchi
Application Engineer
(3,079 Views)
