LabWindows/CVI
cwgraph
How can I use CWGraph with CVI ? I want to use an axis with date format like a strip chart.
(3,069 Views)
If you are using CVI 6.0, you just drop it on your UIR panel by selecting ActiveX and then finding it in the list. Then, the code generator will give you a library to program it. To learn more about programming with ActiveX controls, consult the Online Help under "Programming with ActiveX controls"
Best Regards,
Chris Matthews
(3,069 Views)
