LabWindows/CVI
cviogl texture
hello,
i am using NI cviogl control (from toolslib) to make 3D animation. my program uses low-level GL SDK functions (opengl32,glu32) to draw objects.
i want to use bitmap textures,  but it is not possible with this control. when i create own window using SDK function "CreateWindowEx" or if i have panel in UIR file and i  use function "wglMakeCurrent" to use this panel as rendering context, then i can see bitmap texture on my cube.
i understand, that this cviogl control was designed for drawind 3D graphs using toolslib functions (in .fp) and some low-level gl function are not supported, but is it possible to configure this control window for using textures?
thnx.
(3,168 Views)
It is not possible to configure this control to use textures.  This API is designed specifically for plotting and does not cover direct use of the low-level Windows OpenGL Libraries (GLAUX.LIB, OPENGL32.LIB).
Kristen
(3,141 Views)
