LabWindows/CVI
cvi windows event
I want to create an app using CVI, under Windows 2K, that will start automatically when a specific user logs in and stop automatically when he logs out. The application will dynamically allocate memory. I know I can put the app in the user's startup folder to begin processing. I don't, however, know how to capture a Windows logout event, which I think I need to do in order to free allocated memory. Do I need to get into the Windows SDK to capture the logout event, or does CVI provide windows event handling services? Many thanks, Kevin Redmond
(3,122 Views)
As per trapping shutdown event, you could look at this thread.
However, as you will see in this thread I didn't succeed in managing this issue: I hope you won't have the same difficulties as me.
(3,105 Views)
I have fixed my problem by calling InstallMainCallback and handling the EVENT_END_TASK event within the event handler. This seems to get generated from a logout. Thanks for the help.
(3,074 Views)
