LabWindows/CVI
cvi imagecontrol
我在image control 里面没有getimage 和setimage 这两个函数 .
是不是没有安装完整版组建.
(4,464 Views)
Hi, I wasn't able to understand your question. Google says it is Chinese language but it's translation is not good enough for me to understand your question. Either you repost here in English or post it to the Chinese board
In either case, be sure to add all relevant informations that may help others to give you the correct answer, e.g. the release of CVI you are using and whether it is base or full version, additional modules you are using and so on
(4,435 Views)
Reposted in English: discussion follows here
(4,426 Views)
您好,您需要安装VDM 和VAS 来进行vision的开发。
IMAQ management一般包含的是setimage size/ setimage info等,您是否可以查询到?如果没有,请您尝试重新安装
(4,403 Views)
可以截张图给我看一下吗
(4,400 Views)
(4,392 Views)
我有这个lib 我想让你截一下那两个函数给我看一下 谢谢
(4,388 Views)
