LabWindows/CVI
create leds
Hello,I want to create leds according to an input variable can you help me ?
thank you
(2,328 Views)
Can you explain what you want to do? Does "Create led" mean add a control to a panel at runtime? If so, NewCtrl is the command to use. Otherwise you must be more clear in your question
(2,311 Views)
