LabWindows/CVI
could not run executable labwindows
Hi all,
I have an old problem, maybe it's about compatibilty. I know, that a created program in cvi8.0 is not compatible in cvi7.0. But a created program in cvi7.0 should work proper in cvi8.0, isn't it?.....
I've tried to some programs and it works. It means: cause some reasons, I must make my program with laptop intalled cvi7.0, copy to another PC which installed cvi8.0, and running there. Normally I don't have any problem about this way. But today, a pop up window comes "could not run executable" (see attch). At first I thought that the file was destroyed or something happened by copying. Then I copied again many times, but still it doesn't work.
Thanks a lot
-roni-
(4,750 Views)
hello roni,
take a look at this knowledgebase entry:
Copying a Release Executable in LabWindows/CVI to a Different Computer.
i hope this helps,
regards,
robert h
NI germany
(4,711 Views)
Hi Robert,
thanks a lot! I've just solved this problem. In fact I've just reserved to many large arrays [e.g.1000000000], which are out of the capacity for my poor PC.  Normally I works in Notebook, which is four times faster and has bigger capacity than the PC. And yes, at first I didn't think and count on it.
Thanks anyway!
(4,684 Views)
