LabWindows/CVI
copy whole stripchart to clipboard
Hi all,
Is it possible to copy the whole stripchart to clipboard? I am using the function GetCtrlDisplayBitmap and ClipboardPutBitmap to copy the stripchart to clipboard.
However, this only copies the actual view to clipboard. Is there a way to copy the whole stripchart to clipboard?
Best Regards
Bernhard
(3,009 Views)
Hi Bernhard,
there is no function for doing this.
You only can set the points per screen higher so you can see all points on the strip chart with
SetCtrlAttribute (panelHandle, PANEL_STRIPCHART, ATTR_POINTS_PER_SCREEN, 1000);
Then replot the chart and then you use again GetCtrlDisplayBitmap and ClipboardPutBitmap.
Regards
DianaS
(2,990 Views)
