LabWindows/CVI
compatibility
Hi to everyone,
i just had small doubt after viewing lot of post in forum regarding compatibility.
i have developed driver program for NI 2530 mux in Labwindows 8.5 version. i want know whether this program can be opened or compatible with 8.0 version ?
i know that in LabView its not possible(going forward) ..
give me some exact suggestion.
(3,532 Views)
Hi Praky,
you can find the 8.5 Readme File at: http://digital.ni.com/public.nsf/allkb/1C8886D3C62CC0F58625744700678061?OpenDocument
Among other things it mentions:
Making Backup .uir Files—If you have been using LabWindows/CVI 8.1.1 or earlier, make backup copies of your .uir files. Once you save .uir files in LabWindows/CVI 8.5, the .uir files are no longer compatible with versions 8.1.1 or earlier. You cannot load .uir files that you have saved in LabWindows/CVI 8.5 in LabWindows/CVI 8.1.1 or earlier.
You can save .uir files you create or load in LabWindows/CVI 8.5 in LabWindows/CVI 7.1 or LabWindows/CVI 8.0/8.1 format. Select File»Save .uir As and specify the version in the Save as type option. If you save a user interface with features that were added in later versions of LabWindows/CVI, those features are removed when you save the file in 7.1 or 8.0/8.1 format.
Besides the user interface files, there are no compatibility issues I would be aware of at this point. Is there a specific question you would like to ask / piece of information you came across?
Best regards from Munich,
Peter
Peter A.
Field Sales Engineer, NI Germany
(3,511 Views)
Hi peter,
thanks for reply....
i bought the Labwindows 8.0 student version for my personal practice.
In my Firma they use 8.5 version..but the program is only with .C files, so from your answer i think there wont much problem in accessing it.
As i am new to  Labwindows i had this small doubt...
any how thx once again..
(3,483 Views)
Hi Praky,
if no user interface files are involved you should be fine. Let us know if you do encounter any issues, though.
Good luck with your project!
Best regards
Peter A.
(3,467 Views)
