LabWindows/CVI
compactRIO, CVI, and C series modules
Being used to LabVIEW, not sure how to interface to the C-series modules on my cRIO using CVI.  The project I'm on needs to use CVI, and I have no idea how to interface to my cards -- e.g. writing to my DIO card or reading from an AI channel, etc.
In LV, it was easy and each I/O channel was simply a variable I could drop over to my block diagram and either read to write from/to.  Any pointers in the right direction for this?  I have the CVI real-time module and I know C, but never messed with CVI much..  I've searched and searched, but maybe I'm not searching right or something 😕
How can I read from my NI-9221 card on, say, channel 0 and get a double back representing the voltage that's on that line??  That's the kind of stuff I'm looking for... in CVI?
Thanks.
(3,976 Views)
Hi there,
LabWindows/CVi actually cannot be used to program cRIO.  CVI uses Pharlap, while cRIO uses VxWorks.  See CVI + RT FAQ and here's another more in-depth document regarding CVI in Real-Time.
Best,
Ryan C.
(3,957 Views)
To add to this, while it is true that you must use LabVIEW to program the FPGA itself, you are able to use C to interface the FPGA and acquire data, etc.  Please see the FPGA Interface C API for the download and more information on this.
Hope this helps!
Ryan C.
(3,936 Views)
Thanks! I'll look into this ... and probably be back in here......
(3,917 Views)
As far as I know, when using cRIO-Modules, there is a "generic" network variable engine running.
So you can read it's values using the network variable manager.
Peter
(3,892 Views)
