LabWindows/CVI
colorMapArray
I am trying to use PlotIntensity for my program and am having trouble using a dynamic array for the z values, is this possible.
(3,059 Views)
Helo Jim_81,
When you refer to a dynamic array, are you refering to a dynamically allocated array? If so, check out the following shipping example which uses dynamically allocated arrays with the PlotIntensity function: cvi\samples\userint\intgraph.prj and the following post.
Thanks.
Wendy L
LabWindows/CVI Developer Newsletter
(3,050 Views)
