LabWindows/CVI
chirp waveform
Hey , i am trying to make a chirp waveform in cvi for like two days and the build in function "chirp" just wont work.
this is how i implemented it:
Chirp (100, 2.0, 40, 500, chirpArr);
and this is what i see in the graph:
can someone plsss can solve this?
(1,251 Views)
I've used it long ago and it did work back then. I think you simply need to experiment a bit with the parameters.
(1,195 Views)
Not a CVI guy but from LabVIEW.
Assuming NI used the same underlying dll/function in both LV and CVI, here is how the LV counterpart works,
Inputs
- samples = number of elements in the Chirp array
- f1 = start frequency / sampling rate
- f2 = stop frequency / sampling rate
- amplitude = amplitude of the chirp signal
Santhosh
Soliton Technologies
(1,188 Views)
