LabWindows/CVI
changing panels XY position via code ?
Hi Here is Some info about my program. i have a main panel on which i create about 15 child panels and each child panel has a canvas control on it. i created a scrollbar which moves the xy position of each panel. i could not use the standard panel scroll bar because it is does not allow the amout child panels that i need that is why im rotating the 15 panels. Could someone please explain to me why when i change the childs panels xy position the display updates the panels position so slowly ? and how could i speed this up? Thanks Shako
Help share your knowlegde
(3,161 Views)
Could you also post your code, so that we can see closely how you are implementing this? What version of CVI are you using? At what point does the time delay occur and how long is this delay? Note also this Knowledge Base:
Adding a Scroll Bar to a Canvas Control in LabWindows/CVI
http://digital.ni.com/public.nsf/allkb/33CBB49128DD6A1586256F7C0082EC96?OpenDocument
(3,108 Views)
