LabWindows/CVI
change a string in a subfunction
I have a string and i want to change the original string in a seperate function. So i thought about a reference on this string, but it doesn't work. How can i change a string in a seperate function? I'm using LabWindow/CVI 6.0
Thanks Paco
(3,609 Views)
Can you be more explicit about your task, and maybe send an attachment of what you have tried to do, so that I can check out why it is not working?
Hi!
(3,601 Views)
I have two functions.
void func1(...)
char string[10]="";
char *pstring = &string[1];
func2(string);
SetCtrlCal(panelHandle, PANEL_StringOut, pstring); //StringOut should be ABBA
void func2(char &test[10])
int a=65,b=66,c=66,d=65;
test[1]=(char)a;
test[2]=(char)b;
test[3]=(char)c;
test[4]=(char)d;
I want to write something into the string in func2, and i need this string also in func1.
Message Edited by Paco on 05-19-2005 07:15 AM
(3,602 Views)
First, remember that the first element of an array in C has index zero. I would suggest for your sanity that you start there. Second, don't forget the null byte terminator on the end of a string. So your code should look like (my changes in bold😞
void func1(...)
char string[10]="";
char *pstring = &string[0]; //or just char *pstring = string;
func2(string);
void func2(char test[10]) // note deleted &
// or void func2(char *test)
// or void func2(char test[])
test[0]=(char)a;
test[1]=(char)b;
test[2]=(char)c;
test[3]=(char)d;
test[4]='\0';
Martin.
Martin
Certified CVI Developer
(3,590 Views)
First of all, when you pass a string to a function, you should do like this:
void MyFunction(char *parameter_string) {
//function body
If, calling this function, you want to "be sure" to pass the first element, you do this:
MyFunction( &my_string[0] );
this way you pass the first element, and it's the same of
MyFunction( my_string );
Hope it helps!
(3,581 Views)
Thanks you helped mit alot.
Paco
(3,577 Views)
