LabWindows/CVI
build screen resolution
Does the screen resolution set have any effect when building application?  IS anything compiled differently (UIR files?) based on the screen resolution the system is set to before building?
(3,054 Views)
 as i know, the only effect is when you use panel attribute ATTR_RESOLUTION_ADJUSTMENT, but not sure if this is calculated against resolution in time of save UIR or Build application
(3,040 Views)
The resolution of the development system is recorded in the UIR file when the file is saved. You can see this more clearly if you save your UIR in a text format (Options >> Save in Text Format) and open the file in a text editor. This information is used for ATTR_RESOLUTION_ADJUSTMENT as OVR_CZ mentioned.
(3,012 Views)
