LabWindows/CVI
build does not create executable
Hi, I am moving from Labwindows 2012SR1 to Labwindows 2019
When i try to compile and run or debug (both 32 and 64 bit)I get the message
Build Status (multicars.prj - Debug)
Link multicars_dbg.exe
Failed to copy d:\Users\Langbein\MultiCars\cvibuild.multicars\Debug\multicars_dbg.exe to d:\Users\Langbein\MultiCars\multicars_dbg.exe. File not found
Build failed.
No further information about the issue is given. There are compiler warnings, but no errors
This is not a access rights issue, and the project compiles fine with Labwindows/CVI 2012 SR1
Message 1 of 12
(7,417 Views)
I'd try moving the entire project out of Users folder and see if it clears trhe error: under some circumstances the access to that folder is not allowed..
Message 2 of 12
(7,370 Views)
This was not the Windows user folder, so should not be a problem - I also tried directly on D:\, no change of behaviour
Message 3 of 12
(7,352 Views)
Paths are set in  Build >> Target Settings...  dialog: check there where the output file is expected to be.
Just out of curiosity, have you tried running one of the sample projects shipped with CVI? If that works then there is something wrong in your project file: you may try deleting entire cvibuild folder, next the .cws file and ultimately you may need to rebuild the entire project from scratch.
Message 4 of 12
(7,347 Views)
The paths are set ok
An sample project builds ok, creating the executable
I have deleted the cvibuild folder, and also the cws, no difference.
I have not yet remade my project file...
Is there no way to get an error message from the linker to know why the executable is not created? all the obj files are there as far as I can tell
Message 5 of 12
(7,314 Views)
You also want to make sure you don't have any custom build steps that can produce a failure
Or try disabling the antivirus while building you project. Sometimes antivirus companies uses some heuristics to determine if an executable is infected and sometimes that heuristics has false positives.
Message 6 of 12
(7,306 Views)
Are these options checked?
If yes you should see the build log in the workspace window.
Message 7 of 12
(7,298 Views)
Was there any resolution to this? We are have the same issue, moving from 2012SR1 to 2019. Verified all paths are correct in the project, deleted the build and .cws file. We get no Linker or Build errors, it just fails to create the .dll in one project and the .exe in a different project. We have tried recreating the projects from scratch with no luck either.
Message 8 of 12
(7,209 Views)
Unfortunately there was no soulution for this problem. Now I have the same: A project I used and worked over longer time, suddenly shows the same behaviour. Next day it works for some trials, but then the same error: There is no executable file in the cvibuild folder and CVI generates the error message, that the exe file can not be copied. I also have tried all advices given above.
How you have resolved your problem?
Message 9 of 12
(6,310 Views)
Not for CVI 2019, but I just tried with CVI 2020f2 and there was no problem anymore
Message 10 of 12
(5,796 Views)
