LabWindows/CVI
bits and bytes
Hi all,
I have few very simple questions.
1-  Can anyone please tell me how to reverse the order of  16 bits? for e.g i have 0010 0011 0100 0101
I want this to be  1010 0010 1100 0100.
2-  Is there any command on labwindows which splits a word int two bytes?
(3,868 Views)
You need to read a book on C programming.
(1) Obvious way:
unsigned short ReverseBits(unsigned short v)
    int i;
    unsigned short result=0;
    for (i=0;i<16;i++)
        if (v & (1<<i))
            result |= 0x8000U >> i;
    return result;
(1) Slightly less obvious but quicker way:
v = ((v & 0xaaaaU)>>1) | ((v & 0x5555U)<<1); // Swap adjacent bits
v = ((v & 0xccccU)>>2) | ((v & 0x3333U)<<2); // Swap adjacent bit pairs
v = ((v & 0xf0f0U)>>4) | ((v & 0x0f0fU)<<4); // Swap adjacent nibbles
v = ((v & 0xff00U)>>8) | ((v & 0x00ffU)<<8); // Swap adjacent bytes
return v;
(2) Obvious code:
void SplitWord(unsigned short v, unsigned byte *hi, unsigned byte *lo)
    *hi = (v & 0xff00U) >> 8;
    *lo = v & 0x00ffU;
Martin
Certified CVI Developer
(3,864 Views)
Doesn anybody know the x86 assembly to inline in C to do 8 bit swap and 2/4
byte swap ? I know x86 has those instructions, but my assembly-fu is rusty,
to say the least...
Guillaume Dargaud
http://www.gdargaud.net/
(3,853 Views)
(3,833 Views)
