LabWindows/CVI
binary switch value
hey folks,
quick question.
I am trying to use values from a binary switch to control an 'if' statement, but it doesnt seem to be working right. so i just tried displaying values from a numeric indicator to figure what was happening with the switch values.
SetCtrlVal (panelHandle, PANEL_N22, PANEL_bs );   //bs-binary switch, N22-indicator
I noticed that once the switch was used the value on indicator stayed static even if it was toggled. i put multiple switches and noticed they all give different values for different switches but they never change while toggling, and the values are all over the place altho i set all the data types to 'int' and ON,Off to 1,0 respectively.
thx for n e help.
(5,228 Views)
nvm.... figured out
PANEL_bs is a pointer(altho i couldnt dereference it wit *)...I found i could display the  values using getctrlval to a variable then use that variable. isn't there a direct way to do it ?
(5,226 Views)
In fact, PANEL_bs and PANEL_N22 are constants (not pointers); you will find them #define'd in the header file which is automatically generated by the UIR editor, and included in your program.
You need to get the switch state into a variable, and use that variable to set the indicator, something like this:
int switchState;
GetCtrlVal (panelHandle, PANEL_bs, &switchState);
SetCtrlVal (panelHandle, PANEL_N22, switchState);
I believe that's about as direct as it gets Smiley Happy
Colin.
(5,210 Views)
btw im a noob in labwindows, altho i love coding in C, matlab.
 the weird part is you can use setctrlval to toggle the switch using 1 or 0 directly, or a variable.
SetCtrlVal (panelHandle, PANEL_bs, (1 or 0 or temp) ); // temp =1 or 0
soit seems logical to handle PANEL_bs as an int variable which changes while toggling.
(5,206 Views)
For CVI to modify or read the value of a control, it must know which control and which panel (window) it is operating on. At runtime, panelHandle (an integer variable) uniquely identifies the panel instance*, and panelHandle and PANEL_bs (an integer constant) together uniquely identify the control.
How can CVI find a control if the value of its identifier in your code changes between calls?
Colin.
* Note that the same panel may be loaded multiple times in your program.
(5,189 Views)
