LabWindows/CVI
binary string
Hi ! I usually use the Fmt() function to convert numbers to strings. Unfortunately I can't find the correct formatting string to convert an integer number in a string in binary format.
ex.: number = 17 -> string = "00010001"
How can I achieve this ??
(5,331 Views)
To my knowledge, there is no direct formatting specifier for binary; however, you can use %x to format as hexadecimal which can then be trivially converted to binary.
-alex
(5,331 Views)
Massimiliano,
As far as I know there is not Fmt or printf do not suport binary strings. You can use a liece of code like this to generate the binary string:
static char binary[10];
static int i=0;
strcpy(binary,"");
for(i=0;i<8;i++)
Fmt(binary, "%s%d",binary,170>>i&1);
DebugPrintf("%s",binary);
I hope this helps.
Juan Carlos
N.I.
(5,331 Views)
Very smart !!!! Thank you very much !
(5,331 Views)
One second... I there is a small problem with the code. It shows the bits backwards. Should be something like:
Fmt(binary, "%s%d",binary,(170>>7-i)&1);
That way you get the right bit order.
I hope this helps.
Juan Carlos
(5,331 Views)
Yes, I implemented the function in this way.
Thank you again.
(5,331 Views)
