LabWindows/CVI
avoiding to load the same program two times
I want to have only one copy of my LabWindows-program in memory.  It should not be possible to load a second instance. How to do so? Thanks Busing
(3,085 Views)
A solution to this problem can be found in a sample distributed with cvi: look at oneinst.prj project that you can find in <cvidir>\samples\utility directory.
(3,085 Views)
Thanks  Insert Smilies  Good luck. Busing
(3,078 Views)
