LabWindows/CVI
arbitrary gpib timeout setting
Is it possible to set the GPIB timeout to some value other then the 18 predefined values available in the ibtmo or ibdev functions?  I'd like to set it to a value between 30 and 100 seconds. Thanks.
(4,383 Views)
Hi Graybeard,
Unfortunately I think you're stuck with the 18 pre-defined values.  However, you could do asynchronous calls and then abort them at whatever time you wanted.
Robert Mortensen
Software Engineer
(4,354 Views)
Hi everybody,
How is it possible to abort calls to gpib devices ?
(4,184 Views)
Ronyo,
As it is pointed out above it is not possible with synchronous communication except by waiting for a timeout. With asynchronous you can send the ibstop() to your device to abort the asynchronous command.
Cheers,
-Marshall R
(4,169 Views)
OK Thanks Smiley Wink
(4,163 Views)
