LabWindows/CVI
/Ze external compiler flag
Bonjour,
One quick question about enabling variable initialisation in for loop definition
I can compile an run the code below in CVI in debug mode
#include <cvirte.h>#include <stdio.h>int main (int argc, char *argv[]) { if (InitCVIRTE (0, argv, 0) == 0) return -1; /* out of memory */ for (int i=0; i<3; i++){ printf("Hello Dude\n"); } printf("Press ENTER to exit:"); getchar(); return 0;}
Now I use MSVC 2009 Express edition as an external compiler when I want to compile the Release version
When I try to compile then I got warnings and errors because of the declaration of the variable "i" in the for loop
I though the Microsoft extensions were enabled by default.
Anyway... I went thru the options of the external compiler support
I tried to include the /Ze flag as an additional flag in the External Compiler Setup Dialog box
No way...even with the /Ze flag
When compiling the release version of the code with MSVC 2009, it seems the the declaration of "i" as an int is still a problem
Is there sometinig I missed?
Any idea ?
Regards, Philippe
Regards, Philippe proud to be using LabWindows since version 1.2
(4,019 Views)
You've just discovered that Microsoft doesn't support C99 language features in the Visual Studio C++ compiler.
The native CVI compiler in release mode does support in-block variable declarations, as does the Intel C++ compiler for windows when you use it as the release compiler.
It appears also that Microsoft has no intention of ever making the VC++ compiler support the C99 extensions.
Menchar
(4,005 Views)
Have you tried it with the /TP flag? I don't know if this is supported by the Express version, but it should force C++ compilation rules, including making your declaration legal.
JR
(3,987 Views)
That'll work so long as he writes "clean C" that's in the common subset of C89 (plus the C99 features that NI has added) and C++.
This essentially means to always use function prototypes and not use C++ keywords such as "class" and "virtual".   There are several other areas where conflicts could arise though maybe rarely.  See H&S 1.1.5.
Menchar
(3,973 Views)
