LabWindows/CVI
Xp embedded support ?
why isn´t  CVI supported for Xp embedded  , and will it be in the near future ?
best regards
Gerd
(3,753 Views)
Hi Gerd,
  I don't know NI's official stance on this, but if you:
1. do a distribution for reasonably powerful embedded devices (meets minimum system requirements)
2. deploy full Win32 API as part of the embedded build
3. have no problem running your app in 'big box' XP
then, theoretically you should have zero problems.
And historically, the same was true with NT embedded and NT, again, regardless of NI's official stance.  Now, if you are trying to run your toaster with XP embedded, then you are on your own.  Maybe you should be using a Unix-type distribution if you want to do that--but I digress.
I have been successfully deploying CVI to NT4 embedded devices (specifically industrial touch screen computers on moving machinery) for almost 5 years now.  I will soon move some of those same apps to newer XP embedded touchscreens.  Perhaps it is nieve, but I have no anticipation about the move.  Since NI doesn't officially recognize the embedded distributions of Windows, you may be on your own.  To say that another way (so others in this board don't pounce on my post), using undocumented or unsupported features is beyond the scope of NI's responsibility.  If NI changes something in their next CVI release, it may not work anymore.
Good luck,
Orlan
(3,750 Views)
I have also created a few applications and used them on EmbeddedXP images without any problems occuring.
(3,725 Views)
I am curious about the 100% compatibility be XP and XP embedded. Chris Mathews has on a post the the inp() and outp() functions are not supported in CVI under XP embedded. I am having problems with inp() and outp() on NT4 workstation and CVI6/7 even with the use of driver "cvintdrv.sys".  Does your experience with NT4 embedded handle inp() and outp()  okay?  (I am not able to find a copy of NT4 embedded either just to try it. Any links you know of?)
(3,565 Views)
