LabWindows/CVI
X initial value strip chart
I need to plot a data streaming that is syncronized by an external clock. So, sometimes, the plot starts in a time, different than 0. Is it possible to set the initiaI value for the X axis? Which function or technich shold I have to use to do it?
Thank you in advance.
(2,984 Views)
Gustavo,
You should use:
    SetCtrlAttribute (..., ATTR_XAXIS_OFFSET, ...)
Also, if you're plotting time data, you can change the display format of the chart accordingly. You do that with the following call:
    SetCtrlAttribute (..., ATTR_XFORMAT, VAL_RELATIVE_TIME_FORMAT);
You would then use SetAxisTimeFormat to configure exactly how the axis should be formatted.
By the way. you also can configure these options in the UI editor, as opposed to programmatically, if you prefer.
Luis
(2,973 Views)
