LabWindows/CVI
Windows XP Gui problems
However, when I run the application the 3-D look goes away and the controls have a flat look.. see run-view.jpg
(3,625 Views)
Are these on two different machines, with your design-view being on a box which has the System Themes disabled?
The run-time view is what a panel will look like if the panel attribute ATTR_CONFORM_TO_SYSTEM_THEME is being set programmatically, or if the "Use Windows Visual Styles for Controls" checkbox is checked in the "Edit Panel >> Other Attributes" dialog.
Kevin B.
(3,580 Views)
No, this is on same machine.
Mike Shoemaker
(3,576 Views)
Did you check to see if that attribute was being set to TRUE at run-time? My guess is that it's un-checked in the Edit Panel >> Other Attribute dialog but somehow being set programmatically. You could also try programmatically setting the panel attribute to FALSE at run-time.
Kevin B.
(3,572 Views)
