LabWindows/CVI
Window width for Diff in IDE
When using CVI's "Diff" feature, the two unconfined windows that are created for viewing the two files are narrower than I'd like.  I always have to manually widen them. Is there a way to automatically make them wider?
NI: I suggest that those windows should be 50% wider by default.
--Ian
(3,687 Views)
Accepted by topic author Ian.W
Ian, you can select Window » Tile Windows so you don't have to manually reposition the windows. I was not able to find a setting to change the window width permanently. You can leave product suggestion here: http://digital.ni.com/applications/psc.nsf/default?OpenForm&temp1=&node=
Richard S -- National Instruments -- (former) Applications Engineer -- Data Acquisition with TestStand
(3,663 Views)
Thanks! That tiling option pretty much does it.  Strange how easy it is to overlook a feature...
--Ian
(3,625 Views)
