LabWindows/CVI
Why does Resman.exe require Administrator rights to rebuild device table file?
The program seems to exit with an error code without rebuilding the .tbl file completely unless the user *is* Administrator. Even users that are supposedly given Administrator rights cannot succcessfully run the program.
(2,762 Views)
Hi codemunky,
Thank you for contacting National Instruments. Depending on your version of NI-VXI and your operating system, you may encounter similar errors. The following two KnowledgeBases explain possible solution:
KnowledgeBase 2FSC3MLS: Resource Manager Fails with NI-VXI 3.2 under Windows2000 When Not Logged On As an Administrator at http://digital.ni.com/public.nsf/websearch/BC8DC5D8E093602986256B130068DE08?OpenDocument
KnowledgeBase 16D5OFSR: Resman Will Not Run If I Am Not Logged In As an Administrator in Windows NT/2000 at http://digital.ni.com/public.nsf/websearch/B00FF8622ED65536862565AB004666DF?OpenDocument.
If neither of those solutions works for you, please let me know what version of NI-VXI and what operating system you are using.
Regards
David Shatila
(2,762 Views)
