LabWindows/CVI
Why can't I use a pointer in an argument?
japp of course the pointer should be initialised correctly. Smiley Happy
Message 11 of 15
(1,418 Views)
Hi Mikie,
   You've been working with this function for 20 years, so I suppose you was not using labWindows (i thing it came later...), so I'm wondering on which compiler did you use.... I knew that some old compilers were not strictly ANSI_C-compliant.  I'm just curious.... thanks for your replies!
Have a nice day!
Graziano
Message 12 of 15
(1,399 Views)
I'd been using Microsoft C since the mid 80's.
For the last 10 years, it's been Microsoft Visual Studio C++.
Mike
Message 13 of 15
(1,397 Views)
In addition to what everyone else said, I think the & identifier is only valid in c++, NOT in c.
Note that I say the & identifier, not the & operator. So you can call a function using foo(&a); which passes a pointer to a to the funtion foo by using the & operator in c. You can't use the & identifier in c as in the following example void foo(int &b);
Message 14 of 15
(1,384 Views)
This sort of function definition:
int foobar(unsigned int a, int &b)
    // Acquire some data... then
    b = Data[a];
is OK in C++ (where & is used in this way as a call-by-reference indicator) but not in C. So if it worked before for you, it was most likely in a C++ environment, or using a C compiler that had C++-style extensions.
Martin
Certified CVI Developer
Message 15 of 15
(1,357 Views)
