08-23-2007 02:40 AM
08-23-2007 11:47 AM
08-23-2007 10:43 PM
thanks for your response.
I got 2 version of CVI. which is 8.1 & 8.0.1. for CVI RT i only have 8.0.1. DAQmx is 8.5.
i saw NIDAQmx_lvrt.lib in the folder of CVI 8.1 bin directory. i tried your matter but i not work. i believe is because i cant see the NIDAQmx_lvrt.lib in 8.0.1 bin folder. but after i copy the file it's still not function.
Please advice. thank you.
J.T
08-24-2007 01:07 PM
08-24-2007 08:51 PM
08-27-2007 02:01 PM
08-28-2007 12:23 AM
08-28-2007 10:38 AM
Hi J.T.,
We would like to help solve your CVI RT issue but we are having a little
trouble grasping your entire situation (discussion forums are not always the
best median sometimes). I talked with Jeff and we think it’s probably best if
you go ahead and contact your local tech support team to get a service request
created on this issue. This way we can have somebody talk with you live and
then if needed relay relay that information back to us
Our support teams are really great so go ahead and give them a call. You
can request support here.
Best Regards,
