LabWindows/CVI
When using an asynchronous timer need data protection?
Global variable in asynchronous timer callback function need to protect data?
thank you !
(3,599 Views)
Access to global variables in an asynchronous procedure (like a thread or timer)generally requires a synchronization mechanism.
(3,579 Views)
Asyncronous timers are executed in a separate thread, so they are expected to be running while the user is operating on the user interface and possibly on data collected in timer callback. All this means that you need to protect your data from concurrent access from both the timer thread and the main thread (where the user interface is normally handled) to prevent unexpected  program behaviour.
(3,562 Views)
Thank you very much !
(3,535 Views)
