LabWindows/CVI
When linking a Lib into CVI, error message is given:
I have created a DLL and LIB in Microsoft Visual C++ 6.0, using guidelines given by NI. When attempting to link lib in CVI v5.0 I get the following three error messages,
Bad header encountered while reading external module: 'test.dll'
Aborted load of member "test.dll" from library...
Aborted load of library
(3,099 Views)
CVI 5.0 is not compatible with the default library format in VC 6.0. Click here for help from Ben Schulte.
(3,099 Views)
