LabWindows/CVI
What is wrong with this passing a string reference?
I try to send a reference string to my function and hope it will change the content as desired, but it is not! Here how my bad codes are:
int PassStringReference(char *str_ref)
     str_ref = "return";
     return 0;
void main(void)
       int error;
       char *str="string refrence";
       error = PassStringReference(&*str);
       printf("%s", str);
The result str = "string reference"???
Can someone show me what I did incorrcetly? By the way, I need to return an integer for other purpose, can not use return string in this case!
(3,595 Views)
In your syntax
str_ref = "return";
you are creating a string constant.  You should use strcpy instead.
strcpy (str_ref, "return");
Your syntax
is the same as
PassStringReference(str);
(3,590 Views)
Hello
You should try the following:
void main(void)
int error;
char str[30]="string reference";  // make sure 30 char is always enough
error = PassStringReference(str);
(3,589 Views)
Your suggestion strcpy is working very well. However, I did try with previous codes with 2 variable strings (for easy showing my problem: I described with constant strings) and it did not work???
Many thanks Smiley Happy
(3,581 Views)
I did try but it is the same result, but the other suggest method is working well
Thanks anyway Smiley Wink
(3,580 Views)
