LabWindows/CVI
What is the easiest way to add XML capability to LabWindows?
I would like to use XML to store config files and to generate reports. What is the best way to do this?
(3,475 Views)
You could use the Microsoft XML Parser, it comes with a COM component that you can import into CVI via the ActiveX controller Wizard. You can download it from here
Hope this helps
Bilal Durrani
NI
Bilal Durrani
NI
(3,475 Views)
